Longknife
What would you estimate the HP of this engine? Thanks, LK
The engine is a 76 truck 440 with 32,000 miles. I had the block ball honed and cleaned, and new cam bearings. It has new rings and bearings, and a new Melling HV/HP oil pump. New aluminum water pump housing and pump. The heads have been milled .030, port matched and had the bowls blended, and had a valve job. It has a Hughes whiplash cam lifters and valve springs. The cam specs are... .518/.518 lift
232/245 @.050. 107 lobe separation and 102 installed centerline. The headers are 1-7/8” primary with 3” exhaust and Dynomax race bullet mufflers. The intake is a new Edelbrock CH16 dual quad with the script removed and painted to look like a 1962 Chrysler 300 413. The carbs are 600 cfm Edelbrocks
