PlymouthMakesIt
Sounds like you found a pack of real automotive geniuses... no clue about how an engine works. They've likely butchered your carb trying to fix an extremely simple problem. The most likely cause of dieseling is running low octane gas in a cast iron high compression engine, either put aluminum heads on it or stop running pump gas and use avgas or race gas.
