Pushing for fab k member/frame rail
o1gnah
5:10 PM
Maryland
I’ve been inquiring to this topic for sometime and am nearing completion as my technician nears space to accept my incomplete roller. I purchased my 73’ with bad k member rear mounts. In disassembly had to remove the brackets attached to the frame rail. These contain square “caged”? Nuts that will need to be recreated. While removing these brackets they became deformed which tech says can be straightened. Also everything will need to be very clean to weld. I’ll attach pics of some steps but what am I looking at in terms of labor costs? Is this an extensive repair?
As far as labor costs, its shop rate times how many hours of labor it takes for repair plus shop supplies. That type of work can't be figured with flat rate. Add in that as the repair progresses you'll most likely find more issues. This is all restoration/custom work. Book time goes in the trash can. If costs are going to be an issue, you may be wise to find another car with less problems. Or gain some skills and DIY.
I'm not sure what it would cost. Doesn't appear to be a big job as long as the frame and brackets aren't rusted out. Might be cheaper to get a cheap or used mig welder and do it yourself. Ofcourse you'd need to watch some youtube videos and learn to weld practicing on some similar guage scrap steel. You can probably find one on craigslist or facebook marketplace even cheaper. Or have a buddy with a welder help.
These flux core non gas aren't the best but they should be able to handle that job easily i would think.
You might consider some solid steel/aluminum spacers to replace those rubber K-member mounts. They will improve the handling.
[/URL]
Ok, I did purchase a Amico non-gas welder. I’ve been practicing however I’m keep tripping my circuit because of voltage. Won’t do me much good until I can solve that issue. I’ve had 1 of 2 brackets media blasted no problem. Still need to be further straightened. I’m just antsy 3month waiting garage time.
