glrestomod
**UPDATE**
So sorry for the long delay! Wanted to give everyone an update and thank everyone again for their help!
Following the advice I received here we did the following:
1. Checked the tuning on the newly rebuilt carburetor and adjusted it appropriately.
2. Pulled plug wires one at a time while engine was running and found one plug wire (despite being new) was bad. Ordered a new set that I’ll put on this weekend that are specific for my application instead of universal fit like the current ones.
3. The chrome hasn’t worked since we put the rebuilt carburetor back on. Found the choke adjustment (has electric choke on a 600CFM single pumper Holley 4160) was way far to the right past the marking range on the carburetor. Also, found that the linkage to the choke that were supposed to be underneath the red fast idle cam was above it and wasn’t operable. We fixed that and tried adjusting the fast idle cam screw but can’t get the RPM’s to increase. We’ll look at that more this weekend too.
4. Car backfired (at the intake) while revving it up after putting an old plug wire on in place of the bad one. My friend said that it’s got a timing issue.
So this weekend we will check those things and add the spark plug wires.
Any other advice or suggestions would be much appreciated, as you have all been helpful so far!
