- 7:50 AM
- Apr 13, 2012
- Granite Bay CA
I have almost no experience at all with Edelbrock carburetors. I've used Holley and Holly based carbs if I don't have a Thermoquad in place.
Recently I noticed that a car in my shop has an air cleaner assembly that doesn't sit right on the Edelbrock 800 cfm unit.
The air filter base shaped like this:
Works fine for a Holley because they are longer and thinner due to where the float bowls are on the Holley style carburetors.
The Edelbrocks are more squared off and have a couple of things that cause interference with the air cleaner base:
The choke assembly and the fuel inlet....
These sit out wide. If the neck on the air cleaner base is too short, the whole thing won't sit down right and possibly even obstruct throttle lever movement.
The fix?
The fix?
