1969 Charger with fresh rebuilt 318, A904 transmission. Carb (2bbl) rebuilt, pertronix electronic ignition upgrade (coil does get full 12V). Idles nicely. When A/C kicks in, the motor responds well. Only have problem when in gear (D or R). Won't build up speed, back fires and just runs very rough. Put in N or P, idles good.
Vacuum at idle and when in gear is a steady 18 inches, oil pressure 70+
Ammeter always shows discharge, even with no accessories or lights on. With lights on, gauge shows major discharge. Had alternator tested and produces 12.8V on the bench.
I'm thinking the voltage regulator is not working, and the coil may not be getting a full 12V leading to the rough running.
Any other thoughts?
Thanks!
Any other thoughts?
Thanks!
