67' Belvedere with an RB engine Power steering high pressure hose?
Auggie56
1:38 PM
NW Ohio
I have only found one but it looks way to long. Anyone else have a source?
It might be correct. I changed mine in 2011 and couldn't believe how long it was but it was correct. It gets coiled.
Yes they go towards the m/c and loop back.
Power steering pressure hoses are very application-specific. There are more universal type of hoses that can and will work, but the routing may be different than oem. This may be what you're after. This runs down towards the k frame before going to the steering box fitting, keeping it away from the manifold, assuming you have a Federal/TRW style pump.
1967-68 Chrysler w 4 bbl Carb Dodge Polara Monaco 440 383 PS Pressure Hose | eBay
66 Satellite hose for a hemi don't think you'll find one. Pump end on left.
As long as the ends are correct and it's not too short you should be good.
Thanks, but I have a Saginaw style, with that pesky "O" ring end. This looks like a flair type hose.
Is your pump original to the car or is it a 69-up style?
