LowBikeMike
The ballast resistor will get hot. Its just a coiled wire set in a ceramic insulator. Normal.
Hi there. My gut feeling is that it is rich in fuel/air ratio when warm. You write that you have the pedal to the floor, which is good when starting a warm engine, but is it constantly kept to the floor or does the pedal get pressed and released and pressed again. If you have´nt already tried it, put the pedal all the way down and keep it there. It will help an overly fuel rich motor every time which warm motors have a strong tendency to be most of the time. Some aircraft piston engines are started warm starts with the throttles full wide open and the mixture control lever to engine cut off. Then as it fires, the throttle has to come back and the mixture control must be moved from "engine cut off" towards "rich". Have flown a lot of piston single and twin engine airplanes in my youth, therefor I know this little trick with which I have helped a few vintage car owners that have "excercised" the gas pedal trying to start their warm motor, which only aggravates the overcarburation situation they´re in.So the ole 71 has been giving me some issues as of late, could sure use some help figuring it out. First off, purchased the car as basically a barn find, in horrible rusty shape. Engine is still all original but car has been completely restored since. Ever since I got the old engine started, seems to run great, but restarting it has always been an issue, the starter just spins, but it acts like it's going to start fire every time, in fact if you leave the clutch in, throttle to the floor, the car almost stays running as long as the starter is engaged like it's keeping it running, but once you let off the key, it dies immediately. Carb seems to be getting plenty of fuel, according to the timing light, all cylinders are firing. New cap, rotor, points, coil, regulator, starter and solenoid. Anybody have an idea what else it could be? Am I missing something?
Reference your lights, you need a power probe so that you can apply power to the light in place and see if it works before anything else. If it does then there is either a ground problem or a power problem, just need to play with it until you figure it out. I believe that they do ground through the hood but is the hood providing a good ground via the springs? Point is that scraping the paint under the light is fine but that doesn't mean that the hood is making contact.Okay, well mine does seem to be there and in fair working condition, worked flawlessly yesterday. Perhaps it just needs some time to work back in, I'm sure the car had been sitting an easy 20-30 years before I rescued it, pics attached. As of yesterday, the car is almost back to 100%. I have just two last remaining issues, the tach won't work and the hood turn signals won't work. Not originally a tach car but someone had already installed a tach cluster in it, just had no wiring to it. It now has the correct wiring running thru slot #20 in the bulkhead connector as instructed, but hasn't moved. Being run thru the bulkhead connector, is it not supposed to tie into the fuse panel somehow? Hood signals are also brand new and simply don't work. One of the originals did work before I restored the car. I assume these ground thru their connection to the hood, yes? Could it just be too much paint between the two? I did scrape off a little to see if it helped, no go.
Start with the basics and a known position meaning do not start twisting the distributor unless you are sure there is an issue. If it ran before you did something and then didn't after you did something, then you need to go back to whatever you did and make sure it is correct. It is possible that something took a crap after you did the work but you need to prove that before just randomly turning screws, moving the distributor, etc. If you don't have a FSM, get a download and look up the ignition system, there is a lot of good info in them.Carrying further with my situation, I checked with key on and on the single wire side of ballast resistor and got 9.5 volts. On other side was 7.44 volts. At the coil positive side was 7.06 volts. As well, pulled one spark plug and as it turned over, got fire at plug. I am leaning to distributor or timing issue. Any thoughts?
