SOLD Built 413 drop in ready bracket engine
FJ6 v code RR
8:37 AM
Collins Ohio 44826
Feedback: +3 / =0 / -0
Hi I have a 413 built engine. This is a drop in ready to go today.
The pistons are original max wedge 413 high compression pistons part number in pictures. The block is a 1972 industry block standard bore. Ly rod and steel crank and pistons all balanced together and drilled for a manual transmission. The heads are 1967 915 heads 2.08/1.74 Bronze guides Triple comp cam Springs 10 Degree lock retainers. Cam is a comp cam 555 lift have cam card. Double roller timing chain. The intake is a super victor 2891 and has a king demon 1095 carburetor. Has a 7qt oil pan with windage tray and oil sling. C.a.t sfi Fluid dampener
New Alternator and water pump new plugs and wires and cap and rotor. Comes as pictured
Location is collins ohio 44826
Price is $ 8,500
