wrinkle paint
paul1969cars
2:53 PM
new york
Can anyone recomend a wrinkle paint for the 1969 air cleader. It not a solid black from what I researched more grey /black
See photo attached of what i found
I have my doubts that is factory finish... this one on my Bird has never been repainted. I've heard that VHT wrinkle finish, sprayed from extra distance works well.
I have used Eastwood with good results. Whatever paint you decide to use make sure it's plenty warm when you do it. Temperature really changes the results of how it wrinkles. The hotter the better.
Consider getting it professionally restored here! My wrinkle can't be beat.
Another key is to apply it evenly. I’ve used a heat gun to accelerate the wrinkling.
Yes, a heat gun helps a lot, especially in cooler weather.
There was a member here who could help if you need a pie tin for it... :lol:
I used the VHT from a distance and baked under heat lamps after sprayed on my valve covers. Wrinkled perfectly. Hard to tell, but I guess I have never taken close up photos.
Feedback from the Technical Director of the International Chrysler Collectors' Association about my wrinkle and HP273 Commando valve covers:
He took his 1965 Dart Charger to the MCACN a few years ago. It scored 996 out of a possible 1000 and my valve covers were not included in any of the deductions.
Neener neener :poke:
I have not tried it over a primed surface but I have applied VHT wrinkle paint over the existing on my Hemi valve covers and it worked fine. So I think it would be fine over primer. You might try it first on a small piece of scrap steel. I’m satisfied with the appearance although the VHT may create a finer texture than some of the original pieces seem to have.
