FOUND Glovebox light
Bird 426
6:25 PM
Illinois
Feedback: +1 / =0 / -0
Looking for a '69 Road Runner/Satellite glovebox switch/light and attached harness. Light bulb end of mine is gone.
I have this piece. I will keep looking for the bulb end. If you’re interested make an offer with shipping from CT.
Not sure if this is what you want.
I have the harness and switch in post #3. There is a spring in the back of it, the metal part that holds the bulb is missing? I don't really know what it looks like. Don't believe post #4 is it . The pink wire goes right over to the fuse box on the other side of the glovebox.
Post #2 is very close to what it probably looks like. If I don't find the factory one, I will get the Scott Drake part, it would work.
Thank you guys!
I have a factory glove box light in my Challenger and post #6 is right.
I believe it is the same bulb as the instrument illumination.
Can not believe this, you are right! Upon a closer look, I saw the bulb socket. I just assumed a piece was missing! So thank you so much for recognizing what I was missing. I have an 1893 bulb, tested it with that and it works!
Thank you!
