Maybe just a 3rd gen hemi swap???
I thought about this. The engine runs quiet, no clattering at all. I'll have to look and see if valve adjustment is part of the service schedule.Have you ever had the valve lash checked/adjusted? Might be a tight valve that may cause the misfire.
I've never changed the fuel filter, I'm not sure where it is. My 2007 Dodge only has one in the tank itself.If you change the filter you can take a sample of the fuel.
You may be correct - water in the gas.
If that's the case just try adding some Heet or other fuel additive and keep driving it.
Burn as much as you can then get fresh fuel in it.
There is no trash in the yard. I live in a semi rural area near a big lake. We get rodents, coyotes, rabbits, turkeys and even deer sometimes.And pick up the trash in your yard.
It's probably what is attracting the rats.![]()
The battery is dated 2015! I was shocked to see the date yesterday, I didn't think it was that old. The engine cranks over like it should.How is the battery ? All the electronics in new vehicles put a drain on battery. Had similar problems with 2015 jgc , new battery took care of it.
Thanks, I did. It was replaced about a year ago and looks new. I thought just what you did...that maybe it was chewed and blocking air flow.check the air filter while you're at it......it won't be you issue, but mice can live in the box and jam it up
I went out to drive it to use up some gas but the damned thing barely used any fuel
the fuel system is returnless
Wayne Timing "belts"His Honda might have a non-interference engine, but change the timing belt anyway and check the tensioner and associated pulley.
The Gates company has a downloadable PDF file for timing belts and it identifies whether or not an engine is "interference".
Your Honda FSM should say if your engine is non-interference or not.
Depending on model year and engine for Audi, Porsche (944 family and the 928), and VW I recall 30k to 50k.aren't they supposed to be changed, like a 60-70k mile R&R deal ?
*check MAP &/or MAS sensors, maybe dirty
*O2 sensor (?) acting up
yeah at a min., a check engine liteI would expect the engine management software to be able to detect out of range signals and throw a code for the MAF and O2 sensors. The EPA probably requires it.
