8 3/4 Diff install fluid and friction modifier question
robl72
3:30 AM
RI
Just installed my rebuilt 8 3/4 sure grip In my Charger..
When filling the fluid and modifier I spilled about a little less than 1 ounce out of the 4 ounce bottle of modifier.. Will the small amount of missing modifier make a big difference?
If It does and I need to buy another bottle can I put the whole bottle in or is too much modifier bad?
Also what’s the total amount of fluid needed for a completely dry 8 3/4 rear end? I put 2 quarts in and it does not appear to be up to
the full plug
Thank you!
You should be fine.
I ended up needing 2 bottles in my Bee rear end to get it to stop "spooling" on tight corners. Run what you've got and if have issues just suck a few ounces out and put another bottle in.
BTW... for next time..
I forgot to ask how much total fluid should the Diff take if it’s dry
