Charged440
- 6:37 AM
- Apr 14, 2016
I have a square back alternator that has one field grounded to work with the 1969 setup. How much continuity should there be between the two fields when measured at the slip rings with the brushes removed? The only spec I could find was 5-7 ohms and I'm at 1.7. Before I go replacing it I wanted to ask here if the spec I have is accurate. Thanks
