WTB Looking for a 1968 roadrunner standard dash wiring harness no a/c.
bigbother14
4:14 AM
Winthrop harbor Illinois
Feedback: +0 / =0 / -0
Hello I’m in search for a 1968 roadrunner dash board harness no a/c car it’s also a 4 speed not sure if that matters or not will pay for shipping thank you
I may have it? Do you know part#. I will look for mine.
I have a standard dash harness but it does have a Tach plug.
I can, I thought you didn't want one with tach with tach wiring? i will have to check condition .
Ok, the tail end that goes to the heater area has 3 plugs cut off!!! 11 wires that I believe go to 3 plugs. Sorry, could be used as donor or yours as donor? I compared with the rally harness's I have which are slightly different, and that's what it looks like.
What is it worth to you? It is damaged. Like I said "donor"?
The charger has a ralley dash cluster instrument gauges. Much of the harness could be alike. If you have an existing harness you might be able to use most of it.
But I’m not sure if you are willing to go through the effort. If you have a wire schematic it could give you some insight.
I don’t have a 69 RR harness to compare.
