bigbother14
Hello I’m in search for a 1968 roadrunner dash board harness no a/c car it’s also a 4 speed not sure if that matters or not will pay for shipping thank you
No don’t know the part number it’s a standard dash 1968 roadrunner no tack non a/c 4 speed car if that helps just need the dash board wiring harness thank youI may have it? Do you know part#. I will look for mine.
If it has it it’s a plus i have a tach from another car factory so if it has it it’s a plusI can, I thought you didn't want one with tach with tach wiring? i will have to check condition .
Ok I see what willOk, the tail end that goes to the heater area has 3 plugs cut off!!! 11 wires that I believe go to 3 plugs. Sorry, could be used as donor or yours as donor? I compared with the rally harness's I have which are slightly different, and that's what it looks like.
Will you consider 25 plus shipping?What is it worth to you? It is damaged. Like I said "donor"?
Charger is a rally dash...I have a 69 charger dash harness if it is the same. It could be.....
