PurpleBeeper
I’ve fought vapor lock for years. I want to add a “cool can” for the fuel line. Any recommendations? Anyone have one they’d like to sell? THANKS!
I’m running a Holley blue. I have a clear fuel filter and I can see gas boiling. I’ve insulated the fuel lines in the engine compartment and plan to wrap at least one passenger header pipeMaybe re-route your fuel line outside passengers frame rail? You must not want to run an electric pump.
You might have vapor lock but I doubt it. I would be looking at and double checking everything.I’ve fought vapor lock for years. I want to add a “cool can” for the fuel line. Any recommendations? Anyone have one they’d like to sell? THANKS!
Lol, why they sure can! Still have mine from the late '70s. They can live a loooooong time on the old shelf.......Wow, do those things still exist ?!?!?
Well, I can see gas boiling inside the clear fuel filter (just before carburetors) and my mechanical fuel pressure gauge acts weird sometimes (drops to 3 psi or up to 12 psi) and the car will stop running like it’s out of gas. Cooled off, starts right upYou might have vapor lock but I doubt it. I would be looking at and double checking everything.
Yes. Regulator with pressure set at 5-1/2 psi & mechanical fuel pressure gauge.You have a blue pump and you see fuel percolating ? Something is wrong. What is your pressure ? Do you have a regulator/gauge setup before the carb ?
I concur with the return line route. Should make fuel pressure more stable and reduce fuel heat some.Could be the fuel is dead heading at the regulator, a return line recirculating your fuel would probably help with the percolating/heat issue.
Yes, the fuel dead heads at the regulator & I don’t have a return line installed. I have considered adding a fuel filter with a “vent nipple” to run back to the tank through the normal fuel line (i have a sump welded to my stock fuel tank with 2 outlets, so my factory outlet by the sending unit is capped off)Could be the fuel is dead heading at the regulator, a return line recirculating your fuel would probably help with the percolating/heat issue.
Where is the pump located ? Where is the reg/gauge located ?Well, I can see gas boiling inside the clear fuel filter (just before carburetors) and my mechanical fuel pressure gauge acts weird sometimes (drops to 3 psi or up to 12 psi) and the car will stop running like it’s out of gas. Cooled off, starts right up
Sweet looking small blockRoute the fuel line away from the motor (hear source) and wrap the line in thermosleeve.
Pump over differential. Regulator on passenger inner fender. One passenger header pipe runs horizontally there & I plan to wrap itWhere is the pump located ? Where is the reg/gauge located ?
