Fuel sending unit ground? Spade connection
StckweldinSteve
11:57 AM
North Carolina
I dont have a wire for this spade connection. Is this a ground? Can i just make a ground and connect it to the frame somewhere?
There was never a tab like that on an OE unit, hence no wire to connect to it... You can ground it if you want to be certain you are grounded, factory was a clip from spigot to fuel line (that's grounded to frame by it's clamps and bolts). Most tanks are grounded anyhow by the straps and J bolts.
I put tar paper under my straps to protect the tank .should I remove that?
Photo heinously stolen from @Kern Dog after helping him out a while back. ^^^^^^^^^^^
Similar but different to this sketch ....
I found the booklet that came with that multimeter.
Using it is easy when you're trained in that sort of stuff.
I dare a plumber to immediately know how to use a construction calculator to establish rafter lengths, concrete volume or other stuff that trained Carpenters have to know.
The best place to ground the tank is to the frame. Make a ground jumper with the female spade on one end and ring lug on the other. Attach ring lug to frame. Good source for electrical info: ceautoelectricsupply.com
Thanks. I looped the bare end around a bolt connected to the suspension for the time being. I have to run to walmart for some electrical parts shortly anyway.
