Instructions DCF-017 for Chrysler Electroninc Ignition Conversions
padam
12:35 PM
Canton, OH
I wanted to put this up for reference.
This is a copy of the original instructions I received with the kit I purchased in the 1980's
Direct Connection DCF-017
Revision F Dated November, 1981
Instructions for Chrysler Performance Parts Packages
Electroninc ignition conversions
P3690426
P3690427
P3690428
P3690789
1. Operates at speeds up to 10,000 RPM
WOW - Never thought that was possible with a factory ignition coil , ballast and a Orange Box with all this talk today
LOL
Anyways , for the most part they want your FACTORY Part # 1.4 - 1.6 OHM Ignition Coil along with the FACTORY .5 OHM Ballast Resistor
Plug Gaps @ .035
Then in notes toward the bottom they talk for even more hotter spark throw the garbage can size Accel Super Coil .7 OHM Primary Resistance and their matching .85 OHM Ballast Resistor
Thanx for the instructions - Appreciate it
Back in the good old days of Made In The USA
Mopar Performance had a lot of this info inside there books , just worded a little different with all of the different Ignition Modules
The instructions were clear all this time?
This is yet another example of how some people (myself included) have somehow blindly made their way through things relatively unscathed while deviating from solid advice and guidelines. I never thought about OHM ratings or compatibility. I just grabbed stuff and used it while not even knowing that there was a difference.
It is a curious thing that a man gets older and realizes how much he doesn’t know.
Thanks, Padam.
This is yet another example of how sone people (myself included) have somehow blindly made their way through things relatively unscathed while deviating from solid advice and guidelines. I never thought about OHM ratings or compatibility. I just grabbed stuff and used it while not even knowing that there was a difference.
Thanks, Padam.
My pleasure.
If anybody wants high resolution copies, just give me your email in a PM.
I also realize everyday, how much there is that I don't know.
It seems like the hobby was much simpler 40 years ago
