Power Steering Box
MLB2021
7:08 PM
Calgary, Alberta Canada
I've been giving some consideration to the Borgeson retrofit power steering box, but it requires shortening the steering shaft itself, which is not something I am really keen on. Whenever I change something on my '67 J-code car I only do it if I can put it back to original, and with the orginal parts.
So, that all being said, I seem to recall reading on the Forum quite some time ago that there is another brand of retrofit box available that requires absolutely no modifications, so true plug 'n play. I can't find the post but does someone happen to recall seeing the post?
All help will be greatly appreciated.
No offense meant but it surprises me when I hear of another person that hasn’t heard…
Bergman Auto Craft sells a swap kit that includes a hybrid type coupler that allows you to install a Borgeson box with no cutting.
Bergman Auto Craft is a sponsor of this site too.
Look him up.
The spline count and shaft size is probably different on the Borgeson unit. I haven't bothered to measure and check.
Yeah, you could collapse the column shaft and just use the U-joint coupler but then you lose the plunge capability of the factory coupler.
Ha....
I wasn't thinking of safety as much as I was thinking of the vibration reduction.
