Runcharger
Nice! I still prefer the look of our classic powerplants over the new stuff. That body almost looks 90% finished where I come from.
			Yeah, that’s the reason I picked that setup. It looks really close to the way it originally did (except the color) I just don’t like the one piece belt setups. They look like a hunk of aluminum just hanging on there.Nice! I still prefer the look of our classic powerplants over the new stuff. That body almost looks 90% finished where I come from.
It almost is. Crossing my fingers that there’s no surprises when they do the media blasting. The right rear quarter panel is buckled forward by a hit and run just before I had to park the car. I have the replacement sitting at the shop. You can just see the impact point just above the bumper. The bumper is bent as well.Nice! I still prefer the look of our classic powerplants over the new stuff. That body almost looks 90% finished where I come from.
That’s why I’m putting on the one in post #40 ; )I don't mind the single belt systems, but that one is a bit over the top "Look at me I'm a whole lot of billet"... they look terrible on street rods too. Sort of the newer equivalent of dipping it all in chrome.
Ya, I saw that. For me, a one belt system that looks similar to the two belt you're using would be optimal. Single belt systems have some advantages like easier belt changes, less slip, etc.That’s why I’m putting on the one in post #40 ; )
I have a broken K frame nut on one of my cars too. My plan was to cut out a 2-3" section on the bottom of the rail and weld in a new piece. I'm curious why you would replace the whole frame rail?One of the K-Member bolts would not come out. It finally snapped off and after a couple days of trying to get it out and snapping 2 easy outs in the process. The decision was made to replace the frame rails.
When Divine One had the problem with the bolt, they looked in one of the holes on the rail and it was full of sand and was damp the further down he worked his finger. They were concerned about the rust inside and the integrity of the rail because of the seized bolt. They told me they were going to remove the rail and media blasted it on the inside just to be sure. I just decide to go ahead and put on a new one due to the stroker engine swap. I would rather not have trouble down the road at some point.I have a broken K frame nut on one of my cars too. My plan was to cut out a 2-3" section on the bottom of the rail and weld in a new piece. I'm curious why you would replace the whole frame rail?
I love your car BTW! Looking forward to seeing the finished product!
Thanks for the fast reply!! That’s a big relief for sure. I was worried there would be a bunch of hacking and whacking to make it work. From the look of your setup, it looks like you got the non A/C kit. Did you use the under dash vents? I have been picking up almost everything that the A/C cars had. A/C dash frame, drivers side vent, passenger side A/C vented bezel and all the behind dash ductwork. I’m guessing the best thing would be to call Vintage Air to make the best decision.I can confirm the vintage air kit for the barracuda works just fine.
This is what I ordered. You will be ahead of me since you seem to be using that serpentine setup. I had to get my brackets for the big block. That kit came for a 340.Thanks for the fast reply!! That’s a big relief for sure. I was worried there would be a bunch of hacking and whacking to make it work. From the look of your setup, it looks like you got the non A/C kit. Did you use the under dash vents? I have been picking up almost everything that the A/C cars had. A/C dash frame, drivers side vent, passenger side A/C vented bezel and all the behind dash ductwork. I’m guessing the best thing would be to call Vintage Air to make the best decision.
I actually ordered it from Affordable street rods. Think I talked to Gary. Super great people. They keep a ton of vintage air stuff in stock. They didn’t have the condessor kit in stock at the time of ordering. They were quick to give my the part number and told me summit racing usually had it in stock.Thanks for the fast reply!! That’s a big relief for sure. I was worried there would be a bunch of hacking and whacking to make it work. From the look of your setup, it looks like you got the non A/C kit. Did you use the under dash vents? I have been picking up almost everything that the A/C cars had. A/C dash frame, drivers side vent, passenger side A/C vented bezel and all the behind dash ductwork. I’m guessing the best thing would be to call Vintage Air to make the best decision.
