Hazard flasher for use with LED bulbs
Dusty Dude
7:42 PM
TX
Looking for suggestions as to what led hazard flasher to use in my 69 Coronet. Also need some guidance on how to get the original one out. It works OK just flashes too quickly. I can't see or feel any fasteners securing it to the dash. I have the glove box out so I have no problem getting to it. Guess I could just leave it as I REALLY don't want to take my console out to get to a screw.
Thanks All
Thanks davek. No joy. I'm a bit confused because my FSM shows the hazard flasher to be a two prong unit but the one in the car has three prongs. I have found a couple of three prongs online that come with a ground wire but I have no idea if they will work or not.
3-prong? Somebody changed something. Turns & flashers we’re always 2-prong.
I have changed everything to led on my Charger and I got a pair of 2 prong led flashers on Amazon. Reverse the wires and they work just like original ones. Hope this helps.
I believe you are correct Sir. It appears to me that I mistakenly identified the warning buzzer for the hazard flasher as it was exactly where my FSM says the flasher should be and it doesn't show up on the FSM wiring diagram. The FSM makes a point emphasizing not to confuse the two separate flashers as the hazard flasher is a"heavy duty" unit. I will continue to try and find the hazard flasher. It's got to be in there somewhere. When I find it I will simply replace it with the same PN unit I have on the turn signals and all should be well............. it says right here in black and white. I'm sure the polarity will be backwards of course!
Thank you Sir.
Here is the correct flasher to use with LED's
