that flat tappet cam isn't going to be happy, I would seriously consider fresh assembly lube
I was under the assumption this happened during break in....... carry on
It's either a stock bore or it's .030 over...can't be both.Looking for pics, I wanna say its a '71. Stock bore .030" over.
FYI.....on a GM/DDA 8V-92T diesel engine, which suffered a head O ring failure contaminating the lube oil, GM recommended the use of a compound called BUTILCELLOSOLVE ADDED to the oil, approximately one guart, to absorb and neutralize the effect of the ethylene glycol. Change the oil and filters after 6-8 hours of operation. On a subsequent tear down, no discernible effects on the bearings. Realizing that a 8V-92T engine has a 5 gallon oil capacity. ......just a thought.....How screwed am I? Should I pull the engine right away or just the head? I am certain I caught this right away, it couldn't have run more than 45 seconds with coolant in the oil but that's long enough for it to circulate and get in all my nice new bearings. Experience only here please is a flush enough, if so is there an additive I should look into for getting rid of glycol? Or am screwed here and need to pull the engine no matter what. I still don't know the origin of the leak if its a cracked head, head gasket, or cracked block but I'm tempted to start with the low hanging fruit and just pull both heads.
Here's the play by play:
Fresh build I've been hawking the oil pressure and coolant temp (both mechanical) gauges and she's held solid 180deg so no overheating.
Blew smoke through an intersection, not a little it was a lot (think Uncle Buck), she misfired a bit and I saw the temp gauge go erratic shut her down immediately. Towed it home and found coolant on dipstick.
The Build:
'71 440rb stock bore .030"
Edelbrock Performer RPM heads 84cc
Xtreme Energy Hi-Lift 241/247 Hydraulic Flat Tappet Cam
RPM Performer Intake Manifold
Don't remember pistons but my CR was 10.x something
Felpro 1009 Head Gasket
I would drain the coolant and refill with water after you do....
#1 Retorque the heads to be sure a couple bolts weren't missed.
#2 Pull the plugs and do a compression test to check for a low cylinder.
A compression test will find the the suspect cylinder.
After it's repaired drain the oil overnight.
Refill with diesel fuel. Flush the engine using a couple gallons of #2 diesel fuel....pour it down the engine thru the heads and valley pan with the oil drain plug installed. Spark plugs out. Crank the engine with the diesel in the pan to help flush out the water.
Drain the diesel, refill with 30 weight oil. Crank the engine again ( plugs out) to wash out the diesel.
Start the engine and bring up to operating temp. Run it 30 minutes to help the water to evaporate.
After you are satisfied the coolant is gone drain the oil, refill with more 30 wt. and drive it for a few miles to maybe 200 miles. Keep your eye on the dipstick to check on the oil condition.
You want to use a heavy single grade oil when doing this to keep the film strength good since some dudes is still diluting the engine oil.
I have done this flush deal many times back when we raced junkyard engines in our stock cars. We would flush out sludged up and abused engines every year.
We also flushed these engines at the dealers I worked at...lots of used cars came in with plugged oil systems, leaky head gaskets, etc.
Good luck....
It does look washed down. I got this bad news at a track a few years ago when a cylinder cracked near the bottom of the bore........still ran the number but made caramel soup out of the oil. It was the second race since a fresh build. I had another block but $1200 dollars worth of machining went out the window. Severe core shift made it impossible to even sleeve.My money is on #5 cylinder.
The valley pan gasket was new when I installed it but I didn't paint it, I got a new one and I'm painting it this time. Made the same mistake with the oil pan, did I mention this is my first buildI'd like to see the driver's side head.
Look for a crack in the #5 chamber and also check #5 cylinder wall all the way down.
We're these head gaskets reused like the valley pan gasket?
Spun motor no coolant came out of spark plug holes, probably because I had to start it again to move for the tow truck driver. I also put my torque wrench on 5 of the bolts before I took off the head and they were tight, I'm wishing I checked them all now...Yes, I feel that you are wasting your time doing a pressure test as you already know that water is getting into the crankcase. Remove the plugs and spin the motor with someone watching for coolant coming out of a plug hole. That would be you starting point on which head to remove. You can then inspect the head gasket and look for any cracks in the cylinder wall of the offending wet cylinder. As far as retorque goes, another waste of time. A leak this bad won't magically be cured by overtightening the headbolts. Fel-Pro head gaskets are "Perma-Torque" and do not require a re-torque as head gaskets of yesteryear...
….The other glaring thing I see with that gasket is that the fire ring in the last cylinder is broken……
