- 10:01 AM
- Jul 17, 2008
- South Jersey USA
the one here has the famous "double camel hump" heads
yeah you may actually finish that build someday toowho are we kidding?
this site could use a good Camaro build thread
View attachment 1682151View attachment 1682152
Yeah....known about that for a group of time but don't know yet what dit one is...And there's big and small journal cranks iirc
I measured the bore and stroke and that's what told me it was a 327....noticed that a couple of pistons were really close to TDC so thought I'd see if it would turn and it did and the piston was really close so I measured the ones that were at BDC and the numbers were there.Numbers stamped on the pad will tell you lots, but if theyre gone or pre stamping old enough, you can look at the casting numbers on the block itself; depending upon year etc, look on the top of the block behind the distributor 'hole' and / or on the block side, usually on teh driver side towards the rear. That number will tell you what it started life as.
As has been noted, its not a 327 if its 4 bolt main, but just because its 2 bolt doesnt mean it is....; gotta have those casting numbers or get serious about measuring bore and stroke.
Well, the heads that were single bolted to this thing are the later model heads that use the VC's that screw on in the center....last 3 of the casting # is 193 on both heads and are bare. Was going to post a pic of them but why fer lolthe one here has the famous "double camel hump" heads
I agree, it's do-able. And in the case of a collector block like a DZ it's mandatory.Not if you are careful!! I decked a numbers matching '69 DZ over a $100k Camaro and did not touch the VIN. Wasn't easy, but I did it...
I didn't look up the #sYeah....known about that for a group of time but don't know yet what dit one is...
sorry had to go there
Not sure what the history is of this engine.....the late model heads were just single bolted to the block with a pair of 4 bolt M/T valve covers just sitting on top of them.I didn't look up the #s
but;
mid 90's LT1 heads (?) maybe
or more likely Vortec heads, very common SBC smog era heads
both decent heads (mid 90's LT1 are better, precursors to the LS) if prepped correctly
so it's an older block/short block
someone 'threw' some later model 'bare' (?) heads on
at least you kept it short and sweet![]()
who are we kidding?
Keep talkin' it up there, Jersey boy....who are we kidding?
this oughta pacify the unruly Mopar mob........
Camaros are rust buckets too.......
Me too. I talk trash but I've done my share of chebbys and ferds.I have a soft spot in my head for 327's.
