- 12:08 AM
- Jul 17, 2008
- South Jersey USA
I got this,
Shorter belt.![]()
you win a prize? is this the june giveaway?
I got this,
Shorter belt.![]()
That shorter belt is going to cost a lot of GREEN. Lolyou win a prize? is this the june giveaway?
Please just remember that Bob is trying to help out - and give sound reasoning behind his advice here.Is this an advanced mathematics forum or a general public automotive forum ?
Another classic completely useless, arrogant post.
Awaiting the .... " if I'm to dumb to comprehend respone........." followed by some completely useless jibber jabber.
Don't forget... just my opinion...
Please just remember that Bob is trying to help out - and give sound reasoning behind his advice here.![]()
Big block brackets look longer - but the angle of the kink in the middle is different.Here's a crazy thought: are big block tensioning brackets the same length as the LA brackets??
A string would go too deep into the groove and give a shorter than required measurement.cant we just wrap a string around it for a ballpark mesasurement?
Using the rope at a ballpark won't help with the fanbelt diameter dilemma.yeah, I was gonna suggest a piece of rope...... but I did say ballpark
Redneck fix for the win.
THANK YOU FOR THE FOR THE VOTE OF CONFIDENCE.....it is appreciated. There are many ways to solve the dilemma....i've used the "formula" method for many years for its accuracy.....but maybe not the most convenient or understood........sorry for all the derogatory comments.....cheersPlease just remember that Bob is trying to help out - and give sound reasoning behind his advice here.![]()
Gummies work well.you just need to smoke more.......you've built up a tolerance
Depending on which stock we talk, because later stock alts used that same smaller pulley.The Powermaster alternator has a smaller-than-stock pulley to make the alternator spin faster. The instructions may have even said that you might need a shorter belt.
Actually, I grabbed another small block bracket, and Frankenstiened a longer one. I grafted in a piece of the other bracket, painted it, threw it on... then took Nadine for a brisk romp through the countryside... we're back in business! Total cost - $0@Hilljack68 jack68 Well you get the belt????
Except the alternator is mounted upside down. The adjustment bracket should be on top?? It appesrs to be on an LA engine......Actually, I grabbed another small block bracket, and Frankenstiened a longer one. I grafted in a piece of the other bracket, painted it, threw it on... then took Nadine for a brisk romp through the countryside... we're back in business! Total cost - $0View attachment 1690153
