WTB Wiring help Needed
Murray
11:25 AM
San Jose, Ca
1968 Charger dash wiring help needed. Headlight and dimmer switch connectors messed up. I cannot find replacements for 1968-70. Am in need of used connectors or whole loom, whatever it takes. Thanks.
If can’t find a new connector can always just wire in spade connectors and connect each directly where it goes
Hello, Bob Horman here. I have a used Damaged 68 dodge charger dash wiring harness. The firewall mount block is missing. All the rest of the harness is ok If you cannot find the plugs you need, I believe this harness has what you need bob Horman
I have a good used thumbwheel dimmer plug I can cut from a harness. I would have to see the headlight plug and look through my stash.
I also have the connectors you are needing from parts harnesses. PM if interested.
