If it still bogs you can increase the secondary air valve adjustment by another half a turn.I said I was going to run the car with the 361 to get a baseline, so I did yesterday at St. Thomas Dragway. Not impressive, 17.4 at 81. It had a bog off the line and the trans was shifting early, so I probably could have shaved a tenth with more experimenting, but why bother?
check again in a few days after the converter drains back. if there are no leaks then you're good.Got the linkage cleaned up and reinstalled today and filled the trans with fluid. I went back several hours later.....no leaks
Some of the Street Demons come with a thin steel plate that goes under the carb during installation, not sure if this carb has that.I changed the primary jets back to the 80's, and put in one step richer rods than stock. I am pretty sure that was the setup before I started messing with it on the dyno. I will check the plugs again after the 3 hour round trip to Moparfest next weekend. For those of you who have never seen inside a Street Demon, here are some pictures. Looks a lot like a Thermoquad.
Have you tried the half a turn clockwise on the secondary air valve adjusment?I figured I might be running rich after rejetting the carb for the 400 on the dyno. I put in leaner rods, but that is apparently not enough. I'm going to put the 80's back in the primary and leave the 82's in the secondary.
