- 10:35 AM
- Dec 25, 2011
- White Cloud, MI
Do you run that in all applications, or just the high output stuff? I'm putting a coronet together that's relatively tame (maybe 450hp) compared to some of the monsters on here. Just curious if I need to go that route.MikeATI Super F Synthetic Type F Automatic Transmission Fluid
www.atiracing.com
I just posted the notice because it popped up in my e-mail and I thought I would pass it on. I use and recommend Mopar ATF+4 for a superior Dexron replacement in all stock and many modified uses.Do you run that in all applications, or just the high output stuff? I'm putting a coronet together that's relatively tame (maybe 450hp) compared to some of the monsters on here. Just curious if I need to go that route.
That was the direction (ATF+4) I was heading in.I just posted the notice because it popped up in my e-mail and I thought I would pass it on. I use and recommend Mopar ATF+4 for a superior Dexron replacement in all stock and many modified uses.
