BB BEEPER
Heres my story.
I have a 400 motor, I bought a rotating kit to stroke the motor to 470. That all went fine.
The stroker kit has a steel crank, internally balanced, as my original crank was cast, externally balanced.
When I ordered a new torque converter from a supplier, (that we all know), he sold me a converter that had weights for a externally balanced cast crank. As I just finished this car, and NEVER drove it before the restoration, I started chasing this crazy vibration. I had several mechanics, other car nuts, try to find the problem. No one could find the problem, until I removed the inspection cover for the transmission and I saw the flexplate bolts were coming loose. So I removed them (yes, I had red locktite on them), and locktighted them again. I thought I would call the torque converter manufacturer, to get his input as to why these bolts were coming out. After discussing the problem with him we determined that I didn't have the right torque converter for my car/application. I needed to remove it and send it back. Now he didn't come right out and say that, he wanted me to send the torque converter back to him, have it upgraded for additional money, and then return it to me, all on my dime. I told him that I wasn't going to remove it and let the car sit until they refurbish my wrong torque converter. He then told me to grind off the weight that is on the torque converter for an externally balanced crank.
In summary, if you decide to change any component, make sure you speak to the manufacturer, not the salesman from the supplier. It seems that the suppliers are selling what they have available, not what you really need. They did this on more than one occasion.
1. motor mounts that don't fit, if you return them they offer you about 50% of what you paid.
2. U-joints that were used in a new box
3. Rear axle Dana 60 clutch plates
4. Front wheel bearings, that do not fit the rotors.
