Amp conversion
6t8gtx440
New Member
12:26 AM
Missouri
I have a 68 GTX. I rewired the amp gauge per MADD instructions. Everything works except for the headlight switch doesn't power the parking lights, taillights, flashers or dash lights. Am I missing something.
Did you knock a connecting plug loose on the headlight switch?
The mad conversion really has nothing to do with that part of your cars wiring. Something else must have got bumped loose.
Might want to check your fuses as well.. that's a lot of circuits to all go out .
Would you know if all the switches need to be connected and the panel secured or grounded to the dash for everything to work?
The dash frame needs to be grounded if that's what you are asking.
