69 satellite PS AMD door fitment thoughts
donm
8:53 AM
WV
Coming up on the end of the bodywork and just got everything fitted back up. Needed a new PS door and at the time could not find a good used doner door, so went with an AMD replacement. I know new parts will never match original but it is what it is.
Any thoughts on fixing the fitment, i was thinking bending the gap out brings it close and adding some metal to the brace that comes across to keep it placed. Any other ideas or anyone have the same issue? Also the inner part is lower than the outer a decent amount, not a huge issue, but it bugs me the more i see it
I'll tell you what I just discovered on mine - the slotted holes on the outer skin (where the cat whiskers clip on) where punched out too low and the whiskers will not install as is. This, of course, is after the door has been fitted, painted, glass in etc. I bought this door a few years ago, so maybe the problem has been corrected, but I'd check it before you get too deep into it. I had to add metal to the edges and file fit the gaps yada, yada, yada but I never thought to check the friggin' slots.
And yes, the whiskers fit like a glove on the other door, which is a factory piece.
Good point. I forgot about those, crap. I tossed my old ones, guess ill have to order replacements early, but Ill check the measurements on the repop while they are on the way. Always seems like a ton of little things pop up when the final prep/paint should've already happened.
Make sure that EVERY part fits in the door. Latch, lock pull knob, lock tumbler... etc.. etc.. Make sure the door will latch and sit properly. Mine with the striker fully out had the door 1/4" inboard of the quarter.
We spent over 40 hours on my drivers side door on the Bird. Latch didn't fit, vent window Allen key slot 1/2" off between inner and outer skins etc etc. Hell they forgot to even punch the upper hinge bolt holes.
All covered in my "broke my 7up machine" thread.
I will always go with skin replacement on an original door if I can....but that's just me.... there is bodywork involved when adding a door skin.
And I may have the same issues at fit up.
I leave the new skin "untacked" or "loose" on the frame until the door is hanging on the car......... this allows me to "twist" the door into shape and alignment........ only then do I put a couple tacks on it
Yea .... that I should have done that....:thumbsup:
When we purchased the new door I wasnt sure i could replace a skin. Now two years later, mabye. Already have the door though so mabye on the next car ill give it a try
You could do a relief cut, bend the metal to where you want it, then weld it up.
This is the way. I'll use panel bond, like 3m's 8115, along the perimeter of the door skin, gives you about 1.5 hours work time to manipulate the door for fitment then cures solid. No welding required. Its also rust inhibiting.
So been a year,should be painted hopefully within the month, only two months late from the 2nd date to paint, so 11 months late all together. Anyway all the internals and window felts fit. Little trim here and there along with some bending, but nothing major. Wouldnt get a repop again, unless 100% only option. Here is something that wasnt expected, didnt really notice. The interior upper panel is shorter in height than an original. Mabye this is a one time miss bit if you buy the repop check before you body work it. Here some pics if you can see the height difference in doors 1st two is factory DS. 2nd two are AMD door. Might have to zoom in.
Ended up with a temp spacer to hold the profile and tacked the upper inside just forward of the vent window to hold it in panel spacing
