Anyone use/adapt a 318 Exhaust Manifold to a 340?
Dibbons
9:04 AM
La Paz, B.C.S., Mexico
I have two passenger side exhaust manifolds (casting #3418623s see photo) for the 340 I am putting together and I can't find a driver's side (casting 3418621). I have a pair of 318 exhaust manifolds on the '71 BBody I am working on. Will I be able to use the driver side 318 exhaust manifold on a 340 without major problems? It would only be temporary. Thank you.
Will it work? Sure. Is it right? Nope. I would be more concerned about the exaust pipe you will have to make and re-make with the combination you are preposing.
I would be concern of the engine not breathing right. 340 exhaust ports is bigger.
Could always port match the 318 manifold so there wouldn't be a step....
Measure the vertical of the port, 340 is much taller. Check with a 340 exhaust gasket, check the head and then the manifold. I would say no, will not work.
Could not find a 318 heat shield/gasket when I rebuilt my 318 and tried a 340 exhaust gasket, stock cast iron manifold, no way.
Op has only the opening comment, none after, that was September last year?
Did ya get things fixed up??
Not yet. Still wording on the rebuild. Took forever to find a shop that refurbish connecting rods. Finally find a machine shop that specializes in diesel engines that can help me out with that @ $400 Mexican Pesos each (about $20 USD).
