- 4:32 PM
- Apr 13, 2012
- Granite Bay CA
If only I knew a dude with a lathe.
			Let me know if you find one...If only I knew a dude with a lathe.
 100% got ya covered..
 100% got ya covered..Thanks Nacho and Don.
I have always relied on factory type alternators that I buy rebuilt from the major auto parts stores so I'm not as familiar with the aftermarket units. It would be good to have something that fits stock brackets so if I have a failure when on a road trip, I'd have an easier time finding at least something to get me on the road again.
Is anybody worried about the higher amperage of the newer style alternators against the factory original wiring? That’s always been the knock for the earlier cars, especially the A bodies that used the paltry 38a alternators. Not saying Kern doesn’t have a wiring upgrade, and even a new dash and underhood harness from Classic may negate this worry, but I just wanted to bring it to light in case it’s still a concern.
Mini Lathe shouldn't have any trouble doing what needs to be done...Following this because while I don’t even have a working heater blower, eventually I’ll have AC and will want a good dual belt pulley set up. If it’s a lightly modified Toyota unit I can get at FLAPs all the better. Could this machining be done on a HF mini lathe? I only need flimsy excuses to buy tools.
Not until you add a bunch of items that require more power to be sent through the stock wiring, that is. Because the OP obviously has a rather robust draw if his meter goes down to 10a at idle. So, my question remains, is anybody worried about the stock sized wiring when running an alternator over say, 100a?The PowerMaster I installed is a direct bolt in replacement, and fits the stock brackets with the stock spacers. So far 2 years and zero issues. It is a dual field, so just ground the other terminal in my ride.
I kinda like the Denso idea, except I am not schooled enough to know if because internally regulated, if that should take a dump, are they replaceable or you toss the whole unit?
If your car only needs 40A to run everything, that's all it's gonna PULL from the alternator, whether it's a 60A or 200A. They are not just jamming 200 amps through the factory wiring and bulkhead all the time.
Yes, I always run a #8 from the alt to starter relay. That covers my alternator capacity, I don't run 100A units however.Not until you add a bunch of items that require more power to be sent through the stock wiring, that is. Because the OP obviously has a rather robust draw if his meter goes down to 10a at idle. So, my question remains, is anybody worried about the stock sized wiring when running an alternator over say, 100a?
Stock wiring? If these described added loads are not directly connected to the battery while running a stock charging system that includes the ammeter, connected instead to the alternator, there will be little impact to the stock wiring while the vehicle is in operation. Takes little effort to upsize the alternator charge feed to splice 1, bypass the bulkhead terminals, if still concerned.Not until you add a bunch of items that require more power to be sent through the stock wiring, that is. Because the OP obviously has a rather robust draw if his meter goes down to 10a at idle. So, my question remains, is anybody worried about the stock sized wiring when running an alternator over say, 100a?
Well your the exception.... I've dealt with it a bunch... The low mount big block Sanden is practically un-usable on a hot day.... The small block Bouchlion kit that runs a single belt warns of slippage concerns on the website....I have run both single and dual belts on the Sanden type A/C compressor and found no difference, no slippage with a single. Besides it's hard to find a matched set of belts anymore. I can understand it on the old York compressor.
Careful with that by-pass if running the factory ammeter and factory under dash wiring. Performed the way most of the folks promoting it recommend, it in fact creates a much higher risk of burning wires in the event of a short, as the factory circuit protection is also bypassed or significantly alters it, making it completely useless in an over-current event.Yes, I always run a #8 from the alt to starter relay. That covers my alternator capacity, I don't run 100A units however.
Careful with that by-pass if running the factory ammeter and factory under dash wiring. Performed the way most of the folks promoting it recommend, in fact creates a much higher risk of burning wires in the event of a short, as the factory circuit protection is also bypassed or significantly alters it, making it completely useless in an over-current event.
I have the Big block kit from Bouchillon in my Valiant.Well your the exception.... I've dealt with it a bunch... The low mount big block Sanden is practically un-usable on a hot day.... The small block Bouchlion kit that runs a single belt warns of slippage concerns on the website....
Straight from the Bouchlion website... About their low mount Big Block kit...I have the Big block kit from Bouchillon in my Valiant.
Low mount compressor kits are all about vanity.. "I want A/C, but I don't want anyone to see my A/C".... Hey, hidden is cool, but if your limited to local drives what's the point....What the crap is the point of installing a kit that you can't drive or has belt slip issues? Seems like a waste of money.
