71Beeper
- 6:54 AM
- Nov 28, 2010
- Stoney Creek, Ontario
Doug, I had the same thought at first because of the responses I was getting here.
The original issue was that I was having no brake lights or turn signals.
I did install an original turn signal switch (the one where I JB welded the 4 way to) but it turns out it's no good.
The electrical guy who found the issue started pulling bulbs till the brake lights and signals and 4 ways started working again - and that was with the Re-pop signal switch not even installed on the steering column - it was on the drivers side floor plugged in the main harness and grounded.
He tried to do the same with the original one but could not get it to do anything.
I will fix the front signal housing and put the repop switch on the column and try it.
