- 2:50 PM
- Jul 1, 2015
It all depends on the ampacity of the conductor.....AWG size x length....open air or in conduit, ambient temp....SHOW YOUR CALCULATIONS to support your premise.....otherwise, what you say makes no sense, abstract or otherwise......not just what some uneducated "buddy" thinks or or says......What they are getting at is the block for instance is better to ground to than running a wire to the battery. You’ve got a battery cable to the block, then the block itself, then maybe six inches of wire, which is better than say a 14 wire running for five feet.
For the conspiracy minded, you can find this idea in wiring up an amp. They want a ground within 18 inches of the amp. I went looking for such things when I figured out what they were angling at.
BOB RENTON
