A727 transmission help
Mitch62
New Member
12:07 PM
Virginia
After sitting for a couple years I finally got to working on my 66 D100. The transmission would not shift and is stuck in frwd, low I think. I replaced the frwd and rvs solenoid valves and still have the same problem. How do I unfreeze the the transmission without removing it. Or am I even looking in the right direction. I'm mechanical but no experience with transmissions. I appreciate any assistance.
There should not be any solenoids.
More than likely the transmission will need to be removed and rebuilt. If stuck in forward, the rear direct clutch is stuck applied, maybe a broken belleville spring?
Not sure if you were trying to reference servos vs solenoids? There are no solenoids or electronics in a 727 transmission.
I meant servo's. It shifted when I parked it. Could I possibly have a valve body problem?
Is that a cable shift transmission? When you say stuck in forward does that mean it also wants to go forward when in reverse? If so and the manual valve is working I would think it has burnt and stuck clutches.
yes, I put on new shift cable and the wheel turns forward no matter what gear I shift to. I guess the clutch is stuck from sitting so long. Guess I'm going to learn how to disassemble clean and reassemble a transmission. Thanks for the help.
