Luck
Hi guys long time listener first time caller.
I have a 68 Coronet that I intend on road racing with a dana 60, a833 and a 383 with a 440 source heads, forged crank, cast pistons and unknown rods/compression ratio. I don't remember the cam but it had the word purple in it. It's kind of a dog, honestly, so I suspect the compression ratio isn't very high. 350hp at the crank maybe, but I could be way off. If I recall correct it has 32 deg advance and afr was 12.8 at wot with a Holley 670. I intend to dyno it after the efi swap before moving forward with any boost.
Right now I'm in the process of converting to efi using a megasquirt 2, Holley terminator throttle body, and the ignition will be controlled by a msd6al2 so safety tuning the thing into boost shouldn't be an issue. plan to really play it safe with timing fuel and psi, shooting for the 500hp crank mark.
I've spent a lot of time building this thing and I don't want to blow it up right away. Ive read a lot of different opinions on what the stock bottom end , a833 trans, and dana60 can handle. Some people say 500hp some 650 etc. so what's the general consensus on a 500hp ungirdled factory bottom end, an a833 and dana 60? Is it a time bomb or will it all take the abuse for years?
