Neutral safety switch questions.
P Dubya
11:34 AM
1969 Road Runner. Has been flawless all summer long until last Sunday. Shut it off at a local convenience store to get a bottle of water. When I came back out I had a no crank/no start issue. Played with the shifter (column mounted A/T) thinking maybe the N/Safety switch could be the culprit. Same issue in any shifter position. With key in 'run' position engine started immediately when jumped across firewall mounted relay. I was happy to make it home but have had no time to diagnose where the problem is. Am I correct in thinking the N/Safety switch is my most likely area of investigation? Is there anything that happens in the key switch that activates the N/safety switch prior to cranking?
Could be NSS.
But first have a helper inside the car holding the key to start position while you wiggle the wires and plugs at bulkhead and starter relay and see if it starts. Then you will know which wire are at fault.
If you wiggle them then get in car and it starts which wire was it?
On an automatic trans car the starter relay grounds through the center pin of the neutral safety switch on the trans. If checking the connections doesn't reveal anything I would check for continuity to ground at the neutral safety switch using a multimeter. If there's no continuity it's your NSS. If there's continuity to ground at the NSS, check the wiring from the ground terminal on the starter relay to the center terminal of the plug that goes on the neutral safety switch. I went through this on my GTX last winter, the wiring appeared okay on the outside but flexing it near the plug at the trans caused the circuit to come and go, there was an internal break. Instead of splicing in a new plug I opted for a complete NSS/back up light harness for the sake of reliability. It was around $42...
With a little testing I'm fairly certain my problem is in the NSS. Yellow wire sends signal from ignition switch to relay but I get no ground from from NSS. When I unplug wire from NSS and use a jumper to ground the engine cranks right over...
Pull the plug off the switch, jump the center socket to ground. If it starts, check the center lug on the switch to ground for continuity in Park / Neutral. Do you currently have reverse lights???? If not, possible it's that not the switch and instead the roster comb fell apart inside the trans..
Crawled under car and found wiring harness to not even be attached anymore to switch. It's in pretty rough shape so I pulled the entire boot and harness up to the engine bay. Is there a reputable replacement for this boot and harness? It's only 3 wires and I would be fine building my own if I can get a new boot, this one is quite cracked...
You can get a molded plug with blunt cut wires. As I mentioned in my previous post, you can buy the a reproduction harness for around 40 bucks.
You can get just the plug with pigtails at Rock Auto.
I found both the repair end only and the complete harness. Classic industries I think... About $65 for a complete harness so I will likely go that route. Thanks!
This is my simple 'get me by' fix until I can get a new harness...
Wow, the price went up 50% since last winter…
Considering the NSS harness is, along with engine harness, the easier to get damaged with heat and oil, and considering the price difference, the full harness is a best investment than just the pigtail, which results on get soldered to an very bad aged harness.
I'm kind of having the same problem w/ a 70 Duster 3 pin NSS. It was starting fine - then I disconnected the NSS to install a shifter cable - then it wouldn't start again after I re-connected the plug to NSS... I replaced the NSS on the transmission hoping that was the problem - but still nothing unless I jump it under the hood. Now, I'm beginning to question if I put the pigtail plug back on upside down. But would that even matter? Any thoughts/advice would be appreciated. Thanks
It doesn't matter which way the plug goes as the center terminal is the ground for the starter relay and the outer pins are the back up lights. You just need to make sure the cable is adjusted correct so it is in park and neutral to start. Check the center pin with a meter to see if it is making a ground in neutral and park. In reverse there will be continuity through the outer pins.
Yessir I thought of that too. The cable is just right. I triple checked it. It won't even start if I put it park by hand w/no cable at all. There must be another problem. The wire for the pigtail was kinda long so I re-routed it a different way. The wires are extremely brittle, and I also put a new wire loom sheild over it to clean up the look a little. I think I must've broke one or more. It think I'll try a new pigtail now. Thank you very much on the info on not being able to plug it on upside-down. Oh, yeah, there's no fuse to burn out is there? Thanks bro. Appreciate you man.
Oh yes, I'll check it with a test light/meter too. Good idea to make sure. Thanks
Thanks bro. My set up is a little different on the fender well. But I'll get it straightened out. I appreciate u taking time to send a pic.
