Dash interchange cornet to satellite
2BWIRED
New Member
12:03 AM
Huxley,IA
Can you put a 67 cornet dash in a 67 satellite? I know you can but was more interested in interchangeabliity and compatability.
I think if you have the Coronet dash harness everything will connect. You will have to modify a Plymouth harness.
The dash frame will bolt in. The dash wiring is different and needs to match the cluster.
Charger dash will also interchange, but will be more work with electro-luminescent cluster lights.
It might help if we knew what the OP's goal was.
If it's a need for a working dash because it's missing and the other is complete with wiring and available-
Yes.
If he wants to know if the frame from one will work with the cluster from the other-
No.
Yes.
No.
I have a good 67 cornet ac dash. The dash in the satellite is missing but wires are there. The only thing good on the cornet is the dash but the wiring is not good. Sounds like I would need the wiring harness for the cornet.
Have a close look.
The main thing would be the round, multi-pin connector.
I believe they are close to the same length.
(Unless I'm not remembering right)
Most other things can be extended.
