- 11:56 PM
- Aug 18, 2024
- Virginia Chesapeake Bay
Did the 74 Satellite come with the fender turn signal indicator as an option or was that discontinued in 1972?
My 74 has them so I'm gonna say yes.Did the 74 Satellite come with the fender turn signal indicator as an option or was that discontinued in 1972?
Good information. Thanks.Still an option, but slightly diff design from 71/72 models.
Just an FYI for those looking the top ones are not Plymouth Satellite/Road Runner they are 71/2 Charger. These are 71/2 Plymouth.Still an option, but slightly diff design from 71/72 models.
While 71/72 were smooth and with studs underside
73 and lates are a bit “bulkier” and attached with a phillips oval screw from top
Diff bulb too. Bayonet on earliers vs wedge on laters
True!!!... but still Same or similar design than the Charger ones… and same bulbs and setup.Just an FYI for those looking the top ones are not Plymouth Satellite/Road Runner they are 71/2 Charger. These are 71/2 Plymouth.
Actually they are different. The 71/2 Plymouth lens, the plate and gasket can be removed from the turn signal housing where 71/2 Charger has the lens riveted to the housing making it harder to service if the wire gets rusted to the lens...True!!!... but still Same or similar design than the Charger ones… and same bulbs and setup.
My 73 had themDid the 74 Satellite come with the fender turn signal indicator as an option or was that discontinued in 1972?
