Road Grabber
It would be interesting to know if another converter ordered from that same company is the same or if that converter is a defect and you are compensating for it.
If you machine the crank with a deeper counterbore will that still work for others converters that would have worked?
What is the clearance spec to allow for any ballooning?
If someone is “checking” the fit, what should that be? The converter penetrates into the crank and has clearance in the counterbore?
This coming from a manual guy and has a 340 automatic ready to assemble in the near future. I’d like to know my converter will not cause any problems and want to know how to check that.
I think that you would agree that this solution is only because this particular person had the engine removed and disassembled. Otherwise it’s back to the vendor and get a replacement.
