padam
I think Uncle Tony got all wound up in a knot on that issue however I did buy 8 spark plugs a couple months ago and 1 had obviously been installed and returned then resoldIt may be obvious to some but why do milder cams survive while the bigger cams seem more likely to fail?
Is it because the bigger cams have a greater stress between the cam lobes and lifter faces? Is it that the springs place more pressure on the lobes and lifters that make the oiling even more critical?
I remember the factory recall that Chevrolet had in the 70s or 80s about the failed camshafts in their 350 small block engines. That was supposed to be due to the grade of metal used in the parts.
I’ve seen videos where modern cams and lifters have been tested for hardness and compared to readings taken from original vintage parts. The numbers are either identical or similar so maybe the problems actually do lie elsewhere. Has anyone actually measured lobe taper before installing a cam? How about the crown of the lifters?
That “love him or hate him” uncle Tony had a video where he bought some lifters from an auto parts store and tested them for crown. The ones he didn’t like were returned for a refund. Some time later he went back to the store and bought lifters again and was given the same exact lifters he bought the first time… the store didn’t send them back to the manufacturer as defects, they just put them back on the shelf to sell to some unsuspecting customers!
