WTB Wanted SB throttle bracket
snake
4:26 PM
canada
Feedback: +0 / =0 / -0
I want a throttle bracket for my 71 Satellite 360,so I can get the right throttle cable geology,I don't want to hack my org,will save that for the next owner.thanks .
Contact your local Cable Geologist. Bet they have one. :lol:
I think this is what you're looking for. One is for a B.B. & one is for a S.B. but not positive which one. I think the one on the right is correct. It has a smaller intake bolt pattern. If you could send me measurements of you mounting holes center to center dimensions, I will double check. I don't have any of either intakes to take measurements.
The 1 with the round hole looks correct, bolt hole to bolt hole is 5 inches
I just measured both. The bracket on left (the blue one with the round hole) is 4-3/4 inches center to center & the one on right measures 4-3/8 inches center to center.
I am shure the blue is correct
I have to go out now, but later we can exchange addresses through PMs if interested. Thanks
The "blue" one is a low profile, low performance manifold application. (I.E. 2bbl)
It might not be tall enough to get a straight shot from the carb stud to kickdown pivot.
The one I clipped and showed is a factory 340-360 4bbl aplication
Yes, shipping included. PM me for address exchange when you're ready.
I will try the one on the right not the blue one.Don Pell 52 Charlotte st Belleville ont Canada k8p 1e4.can I sent you a money order in US money.thanks very much .
Thanks for your help.
Thats fine. I'll send you a PM with my mailing data.
Sorry undecided now after looking at the pictures for the last few days,I think there could be a problem with the kick down rod,with your bracket,with it being much higher not shure my rod will left up higher if that makes sence.
No problem. I think the one you wanted is from a 4bbl big block Mopar & the other may be from a small block 2bbl 318 Dart that I once owned.
