Ecu terminals .... anyone know what kind ?
Canadian1968
3:14 PM
london
Does anyone know what style / name the pins in the Mopar ecu are called maybe where to find them?
A rubber plug goes there. Search chrysler 1976 ignition control module pigtail. Saw them on ebay, kinda expensive. And it doesn't come with the special center screw. Which doesn't help.
I'm looking for the brass male terminals only . I tired looking up the wire pig tails to see if they would name the femal terminals but no luck
Think I may have found them?
I'm playing around idea of making a HEI conversion mount . So instead of people having to cut wires and what not. All you would need to by pass the ballast . The just plug your stock harness directly into my piece that would have oem style plug but house the hei module . If you ever want to switch back to Mopar ecu 5 min swap, no wires cut no damage done !
For anyone wondering , those are not the correct pins.... I didn't pay attention to the size... there were 2mm long haha exact shape.. but 50 times to small !
Search continues
