gtx6970
Are you sure that it’s not leaking through the throttle shafts? I think that I had heard somewhere that when they wear they could leak but I would think that they would leak air in and not fuel out. Also they would leak when the engine was running as the air/fuel was flowing past the shafts. While you have the carb off the car hook an electric fuel pump to it and confirm were the leak is. If it doesn’t leak it has to be the shafts I would think.
It had fuel running down the side of the carb body , So Im 99% sure it had either a binding float or stuck open needle/seat
Its back together and running. Drove it to a local cruise near me Saturday .
Plus had it running a while in the driveway yesterday for about half hour to monitor fuel pressure
No leaks - flooding = so far so good
