fullmetaljacket
- 9:37 PM
- Oct 15, 2010
- Brooklyn, New York
What's the compression on that 6.4? Why would a starter fault line like that?
I love it.How's that Stef's oil pan?
13.5 compression.What's the compression on that 6.4? Why would a starter fault line like that?
That there sounds like the culprit that damaged your starter. The kicking back donkey is detrimental to the starter castings.13.5 compression.
I got the 1st MMX/microsquirt ignition setup right off of the dyno last winter when Molnar sent me the wrong reluctor wheel to use the MSD 6-hemi controller.
I was having issues early on trying to figure things out with it.
It would backfire and kickback when starting sometimes.
Technology is amazing.Bob, I see your running rocker arm stabilizers. Are the rocker arms stock or aftermarket?
Are you willing to talk about your cam specs or is that proprietary info? I have been considering a similar build, talked to MMX and Arrington a few months ago. We didn't talk about the cam though, and I will be running a pump gas compression, around 11 to 1 or less.
