Power brake conversions
Spuzzy
1:37 PM
South Dakota
Here’s a question for 65 Coronet owners that have done a manual to power brake conversion. All the setups out there use the goofy brackets to alter the linkage and I suppose multiply the braking power. But it also raises the booster and master cylinder quite a bit. I have tried 2 units in mine and one was 9” booster and the other was a 8” unit. Neither would allow the hood to close. Keep in mind that the 65 Coronet has a rather flat hood. Can anyone share their experience in doing theirs?
Hello
I have a pirate jack set up in my 65 and clears the hood
I admit it looks a bit goofy but it works just fine
My pushrod goes in the top hole and the brake switch lines up with a little fiddling
Dan
To Sixpactogo:
I’m pretty sure that setup is for cars that originally came with power brakes. Mine did not.
To Sixpactogo:
If so, why would they include the bell crank linkage and firewall plate? If you already had power brakes you would not need those two items.
