The pix shown uses a HYDEN THERMAL DRIVE FAN CLUTCH......fyi.....
BOB RENTON
No **** Bob, do you think I’m stupid? I asked the question because that’s the easiest way to differentiate between a thermal and viscous clutch…
BOB RENTON
I don't know if you're stupid or not......just a guess....perhaps you did not know it's Hayden unit.....No **** Bob, do you think I’m stupid? I asked the question because that’s the easiest way to differentiate between a thermal and viscous clutch…
Yeah and it's very cheap. Simply based on the posts I encountered while looking for this I would avoid. Also read plenty of argument about the air volume. So that's not why I am even after the fan, I just want to restore my A31 components. Not the best answer but that's the totality of knowledge I got after a few hours reading on here and the other forum.Reviving this thread, a couple of questions about clutch vs solid fans. Do the Hemi/440-6 Torque Clutch aluminum fans move as much air as a fixed steel solid fan? If so, is there an aftermarket equivalent to the Mopar clutch? I thought I read somewhere that there is a specific part number Hayden clutch but now I can't find where I read that.
Thanks,
Jim
Good stuff, thanks for sharing. So it looks like HD or Severe Duty clutches operate up to 90% water pump speed so pretty close. It talks about fan pitch, anyone have any info on the angle for most 60's 70's Mopar fans? Thx
This just came in handy! But I'm having trouble finding the spacer. I dug up a couple part numbers but I can't match them with available parts.70 - TORQUE FAN DRIVE PN2806070
_______________________________
1970 Coronet and Charger are sister cars. Your car and my car were both built in St. Louis. I would expect shared parts to have identical part numbers.
