A31 package 7 blade torque drive fan stuff.
The pix shown uses a HYDEN THERMAL DRIVE FAN CLUTCH......fyi.....
BOB RENTON
No **** Bob, do you think I’m stupid? I asked the question because that’s the easiest way to differentiate between a thermal and viscous clutch…
I don't know if you're stupid or not......just a guess....perhaps you did not know it's Hayden unit.....
BOB RENTON
It's a viscous clutch. So yeah, need the correct fan and clutch combo. Drats.
2863216 fan
2806070 clutch
Reviving this thread, a couple of questions about clutch vs solid fans. Do the Hemi/440-6 Torque Clutch aluminum fans move as much air as a fixed steel solid fan? If so, is there an aftermarket equivalent to the Mopar clutch? I thought I read somewhere that there is a specific part number Hayden clutch but now I can't find where I read that.
Thanks,
Jim
Thanks,
Jim
Yeah and it's very cheap. Simply based on the posts I encountered while looking for this I would avoid. Also read plenty of argument about the air volume. So that's not why I am even after the fan, I just want to restore my A31 components. Not the best answer but that's the totality of knowledge I got after a few hours reading on here and the other forum.
Some info from Hayden. The link is for a PDF file.
Adobe Acrobat
Good stuff, thanks for sharing. So it looks like HD or Severe Duty clutches operate up to 90% water pump speed so pretty close. It talks about fan pitch, anyone have any info on the angle for most 60's 70's Mopar fans? Thx
Look at the third line on your Broadcast Sheet for the two digit codes under 'FAN' and 'FAN SPA'.
For 1970 Chargers there are three different part numbers for 7-bladed fans. Which two digits are on your BS?
16 - 7 BLADE PN2863216
23 - 7 BLADE PN2863223
24 - 7 BLADE PN2863224
For 1970 Chargers there are two torque fan drives. Which two digits are on your BS?
FAN SPA: Fan Spacer.
59 - 1.06" FAN SPACER PN1851959 WITH TORQUE FAN DRIVE PN2863259
70 - TORQUE FAN DRIVE PN2806070
Have your BS information on hand when you call an outfit like Mancini Racing and ask for restoration parts.
_______________________________
1970 Coronet and Charger are sister cars. Your car and my car were both built in St. Louis. I would expect shared parts to have identical part numbers.
This just came in handy! But I'm having trouble finding the spacer. I dug up a couple part numbers but I can't match them with available parts.
Anyone have a direct link to or photos and info on the correct fan spacer for this? I did a lot of research but can't seem to locate the part. It came with that 7 blade fan and a torque driven clutch.
