Help with brakes
I used a MBM MC1323 m/cyl and removed the rear residual valve. They're both 7lb
The front discs should never
be more than 5lbs. where
2lbs is more or less standard
7lbs for the rear drums is
bordering on minimal and
should be closer to 10lbs.
I run a 2lb front and rear on
a 4 disc system. 1-1/8 MC
bore. Has good firm pedal
I'll bleed the brakes again when i get back from holiday
There was an air bubble in one line and the proportioning valve wasn't dialed in. Once those two were addressed we're good to go
Thanks for the help everyone
